Hello All,
My pool is about to go through a complete remodel. I am adding a used Goldline SWCG. I also plan on automatically muriatic acid. I need to install a pH probe and when the pH drops below a certain level, the acid will be dosed. For the pH probe, I plan on having a 2" x 2" x 1/2FIPS PVC fitting. Then I plan on fitting a probe fitting into the 1/2 PVC fitting. The pH probe has a gas bulb. Do you think that the pH probe will be able to survive in setup that I am proposing? Has anyone done this? How did it work for you?
Thanks
Minh
Thanks
Minh
