Thread: Aquatrol and salt calibration
    Jul 2008
    Solon, Iowa
    170
    Salt strips and the pool store water analysis agree - my Mineral Springs (Goldline Aquatrol) SWCG unit is under-reporting salt by about 500 ppm. The unit was new in June. Can this particular unit be recalibrated or is salt concentration sensing by electronic means an imprecise affair? I hate being force to keep my salt concentration no lower than 3300.
    Kelly
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    Guest
    Re: Aquatrol and salt calibration
    Goldline seems to feel that if the salt reading is within 600 ppm then it's within spec. Your unit is not measuring salt but rather conductivity and then approximating the salt reading from that. The conductivity will change not with only salt concentration but also temerpature.
    Jul 2008
    Solon, Iowa
    170
    Thanks, Waterbear. I guess I'll just adapt - worst case is I have to keep salinity in the higher end of the range vs the lower.
    Kelly
