I ran on high because thats what the experts on here suggested as part of the shock process. Makes sense that you want the water circulating as much as possible at that time, but I guess you COULD do it on low speed if you wanted. My pool is about 14,000 gal.
You may not have to run the pump as long as you think once you have the water cleaned up. Try to back off a little bit each day on the run time and see if the water is still clear. I think alot of people run their pumps more than they need too and electricity isn't cheap.
