I'm putting in my new filter soon that just came the other day.Right now its reading about 16-17 lbs.After I cleaned the old one it was at 13 when I put it back in. Now is getting back up to to what is was when I moved here 2 months ago.
No one has been using the pool either since it been to cold to keep it heated I've just been adding acid to get it lower and some bleach weekly to keep get inline and running the pump a few hours a day for now until I get my own kit.Due to what the pool store says it is now.
The old filter was in bad shape I have to admit,so How can the pressure keep going up with only surface dust being filtered out for now?
I was told by the local pool store the best way to know what it should read is check it with no filter in it first.
Does this sound right to you guys or should I just put in the new one and go from there from now on??
Cant wait till my Taylor k2006 test kit gets here so I can learn how to use it.I've only used the two way OTO and PH kits before for my hot tub up north
and that was easy and I keep the water great with that.
Thanks for the Forum Guys!! I been reading a lot on it trying to figure out the best way to keep it sparkling clear like it is now without spending a lot.
