I'm down in southwest Parrish,Fl. and its been kind of chilly here this winter about 50-70 degrees and we are not using the pool now so I'm keeping it heated to about 60 for now till it warms up more. Since I'm new to owning a pool here I have only been filtering it about 6-7 hours a day. haven't had to do much to keep it clear so far just putting in some bleach once a week and some Muriatic acid trying to lower the PH down a bit after some rain.
Last test from the pool store the TC 5.0. FC 5.0,CC 0.0,pH 8.0 acid demand 2, TA 90 CH375 Stabilizer 140 total dissolved solids is 1,100 ppm.That is According to their tests though.I just ordered my own Taylor K2006 kit the other day and a new filter.I was just wandering if what I'm doing for now is OK or should I run the filter for a longer or shorter time.I'm sure when it gets hotter and we start using it Ill have to do it longer.
