Hey all.
After years of resistance, I think I'm finally fed up with dumping bleach and pucks into my pool
So highly considering a SWG at the start of this swim season. Just have a few questions...
I run my pump / filter 24/7 May - September. I know its overkill, but Ive done it for 10 years and am very comfortable with maintaining it this way.
Will doing this become an issue with a SWG? Is there an issue with burning out the cell quicker because of this?
My pool has an attached spill over spa. Before switching to bleach a few years ago I used a chlorinator. The problem I was having was that when I switched to spa mode, the chlorine level in the spa became much too high. So when switching to spa mode, I had to turn the chlorinator down to its lowest setting or off completely. Will this also be an issue for a SWG? If so, is it possible to turn it off or down so the CL level in the spa doesnt get out of hand?
My last question is a little silly but a concern. Ive swam in a few SWG pools and they had a very heavy taste of salt. Even though I know we arent supposed to be drinking the water, it was pretty gross Are there SWGs that require less salt? My thinking is less salt will equal less salty tasting water? Is this somehow controllable?
Thanks a million everyone!!!
