My TA is pretty high -- 240. Otherwise, all of my numbers are in line. This is a new pool so I suspect it just picked up a bunch of junk, plus they had to fix a problem with the PebbleTec on the baja shelf (by draining the pool down) and redo some, so I suspect some debris from that made it into the rest of the pool.
I know it says to lower the pH then aerate the pool. How long do I have to aerate for and how many cycles might this take to get to a better number?
Thanks!
- Jeff
Thanks!
- Jeff
