I have removed my IC40 SWG for the winter and I also reconfigured Screen Logic so the SWG is not connected,
but I’m bewildered as to why I’m receiving Pentair Alarm Notifications in my email after doing this.
Has anyone else had this problem?
Here are the errors I’m receiving in emails:
Alarm Details:
Chlorinator: Low Flow Error - Check Chlorinator flow switch for blockage. If running IntelliFlo pump, you may need
to increase the flow rate.
Chlorinator: Cold Water Cutoff - Chlorine feed is shut off due to cold water
temperature.
Chlorinator: Communication Lost - Comlink to the chlorinator has failed.
Alarm Details:
temperature.
