Thread: Help, dirt keeps running on to my deck!!
    Jun 2008
    Florida
    12
    Here is my problem. First of all, my yard is really sloped funny...it angers me every time I think about it. It's like the builders had no regard for anything. My yard slopes toward my house and pool, except in the front.
    So basically every time we get a heavy rain, I end up with clumps of dirt on my deck, on all three sides. It's very annoying. It's screened in too. It's actually getting between the little gaps at the bottom.
    What can anyone recommend to help stop this. I was thinking landscape with rocks around the edges of the deck. Or is there some type of shrubs I can put on the outside to help this? My neighbor doesn't have this problem, his yard slops away from his house.
    14 X 30, 15000 Gallon
    In Ground, Gunite
    Built 1994
    No automatic cleaner (it broke)
    Using the Pool Buster Vacuum
    divepool's Avatar
    Aug 2008
    St. Charles IL
    37
    Re: Help, dirt keeps running on to my deck!!
    Best to post a picture, but sounds like the best solution but not the cheapest is to call in a landscaper, and possibly build a retaning wall.
    22x52 IG 56K gal 3.6' to 11.6' deep, TruTile w/Vinyl Liner IG pool w/ 12" wide safety ledge
    StaRite System 3 Cartridge filter 450sqft S8M450, Pentair IntelliFlo VF pump 3.2KW
    Hydronic in floor heat & StaRite SR400HD, Pro Logic PS16 w/2 40K Turbo cells.
    4 Hayward Colorlogic lights, Dolphin DL3002 Robotic cleaner
    Saint Charles, IL
    Mar 2008
    League City, TX
    144
    Have you considered installing drains in the yard around the deck? Or you may have to have the yard graded away from the house / pool.
    Pool completed in the fall of 2008.
    Landmark's pool build
    Freeform 26' x 45' IG gunite, 4' to 8' deep, 29,500 gallons, WetEdge PearlMatrix Tropical Mystic, Freeform 8' X 11' Ultimate 16 jet spa, 38' moss rock weeping wall and 3 waterfalls,
    4 pumps (Intelliflo 4X160 filter pump, WhisperFlo 3HP spa pump, Pentair 2 1/2HP WaterFall pump, cleaner booster), EasyTouch 8 controls, Quad DE 100 filter, MasterTemp 400K heater, Pentair Legend Platinum cleaner, 995 sqft. Sundek.
    Mar 2007
    Morris, IL
    477
    I would suggest one or a few retaining walls. Depending on how much material we are talking, digging it out all the way to your property line and retaining the dirt back there is probably ideal. you could then slop it more to the sides and swail it out to the front, or even dig in some drain tile and connect it to the one you would put in behind the wall and run it out front. Builders who all the house to be built with the dirt draining drastically in towards the house should be sued in my opinion. Whatever you do will probably require alot of work, and a considerable amount of money. But doing it right is going to be your best solution. Or else you get to make a mess all over again later. If you can do it, then do it yourself. Rent a bobcat or two and get a pile going, once you get a load or two call a truck in to haul it out for you. Make a dirt ramp so you can load it and have all the dirt close. They will probably insist on being paid by the hour getting loaded by a bobcat, but when it is all said and done it may be cheaper than paying someone else.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Jun 2008
    Florida
    12
    Thanks for the replies. Yes I was thinking the retaining wall/bobcat idea too. I agree this will be a lot of money, I think we will try to do a little at a time and do a lot of the work ourselves.
    In Ground, Gunite
    Built 1994
