Hi,
I am noticing some problems with the grout in my 1 year old pool. My pool is a concrete pool covered entirely in 4" tiles with grout in between.When I rub the grout even with my finger if feels slightly slick and I get quite a bit of white flaky powder coming off the grout. I spent a day scrubbing all the grout lines with a hand brush and it is better now but I'm worried this may be due to an imbalance in my pool chemistry. After I was finished scrubbing it turned the pool cloudy from all the grout residue. I let it settle and vacuumed and the pool was clear again.
My normal CSI runs around -0.3 which I understand shouldn't be corrosive to plaster.
FC 3.8
CC 0
PH 7.5
TA 70
CYA 55
CH 410
Salt 4500
Temp 30c
Borates 50
I am in the process of draining some water to lower the CH to around 350 but when I run the numbers using the pool calculator it shows me I would need a PH of over 8 to maintain a CSI close to zero. Does this seem right?
Also what could be going on with my grout other than corrosion?
Any suggestions or information will be greatly appreciated.
FC 3.8
CC 0
PH 7.5
TA 70
CYA 55
CH 410
Salt 4500
Temp 30c
Borates 50
