I had pool service up until two weeks ago, and they pretty much came once a week and were shocking my pool. I am getting more situated and can start testing my pool on the regular now. This was also the last time my pool was vaccummed and mine is coming in Tuesday.
My pool has stayed really clear for the two weeks and I have been pouring 10.5% chlorine to keep it clean, and the pump is running for 8 hours each day.
I am trying to get to go in the pool tomorrow, and I'm hoping the FC levels should be above the minimum safe levels.
Pool
16K gallon - Chlorine
Screen Enclosure (no leaves or any large debris)
Clear water and easy to see the floor
Temp - upper 80s
Weather
Been raining a lot, but the past few days it's be a bit lighter. I did have to drain the pool at one point due to the rain.
Kit
TF-100 XL
Chemicals on hand
4 gallons of 10.5% chlorine
.5 gallons of Muriatic Acid
What tests do I need to run?
Do I just pop my results into the Pool Math Calculator?
Should I go ahead and buy some stabilizer just in case?
Pool
Temp - upper 80s
Weather
Kit
TF-100 XL
Chemicals on hand
