Ok here we go. I had a CYA of around 180 & just finished partial drain and refill. I tested water with K-2006 then took water to pool store for test to compare results.
K-2006 results
Fc 4
Cc 0
Ph 7.8
Ta 160
Ch 20
Cya 30
Pool store results
Fc 3.3
Cc 0
Ph 8.1
Ta 190
Ch 50
Cya (said they couldnt test it because ph and ta were out of wack)
Pool store says add 9 qts 14 ozs of muratic acid. 17lbs 8ozs of calcium plus.
Pool calculator says 55ozs of acid and 625 ozs of calcium plus 39lbs..
Help please...
Brandon, MS
20000 gallon in ground vinyl
sand filter
hayward super 2 - 1 hp pump
K-2006 results
Fc 4
Cc 0
Ph 7.8
Ta 160
Ch 20
Cya 30
Pool store results
Fc 3.3
Cc 0
Ph 8.1
Ta 190
Ch 50
Help please...
Brandon, MS
sand filter
