- Aug 2, 2008
- 1
My grandchildren got an above ground pool again this year. I thought I would install a saltwater system so the water would stay clean this year. I also installed a more powerful pump. The problem is when I run the saltwater system. Yellowish frothy bubbles form on top of the water and sit there. I can scoop them off and as long I only run the regular pump, they will not form, but if I turn on the salt generator back on they begin to form again. I thought it might be because the PH was too high, so I lowered it, and it has not made a difference. The pool water comes from a well, I don't know if that has any effect.
Can anyone give me some advice?
