Is water supposed to come out of the waste port when I move the valve to all the different positions?
It doesn't expel water out of the waste port on filter mode though
I'm gonna go mess around with it some more and get more details.
Water should come out the waste line on those settings, but Winter is not designed for pump operation. As long as it doesn't come out during filter or recirculate, you have no problems.
Waste flushes excess pool water to the waste line. Backwash runs water through the filter backwards and out the waste line. Rinse runs water through the filter like normal, but sends it out the waste line instead of back to the pool.
I just want to add that when you change multiport positions, all the ports open, so it's 100% normal to see a little water come out of the backwash port, as long as it stops when the pump is on filter-- all is good
