We are leaving for almost two weeks. The pool is new. We can set the variable speed pump on a timer. My thoughts were to shock the pool, leave our cleaner in the pool and set the pump to run 3 hrs at 3450 rpm so the cleaner works, and then run at 600 rpm the rest of the day. Any thoughts on this? We also have an auto fill so I'm not worried about adding water. No trees so the only debris would be bugs and small dirt particles due to construction next door.
Thanks for the help!
