Howdy.
I'm totally a rookie for pool maintenance. I feel so grateful that I could find here and learn valuable tips from your guys.
I have a fairly large SWG pool with spa in Tx, 32ft x 25 ft x (4.5 ft ~ 8.0 ft), about 24k~25k gallon water.
I normally went to local pool stores to have free water tests weekly. I'm not saying that I dont trust them, but i think that it would be better that I could know more and do some tests by myself first, instead of 100% doing whatever they said without knowing why. Anyways. so i decided to order my first water testkits, TF100, according to recommendation here, and I should have it shortly.
Following results based on most recent tests from store
pH: 8.0 --> (I have added 1qt of gallon muriaric acid, after I got home)
FC: 0.5 --> (after running pump 4 hours since adding acid, I pull 56 fl oz bleach 8.25%, calced by poolcalculator.com)
CYA: 50~60 ppm
salt: 2600 ppm
TA: cannot remember number, but it's in okay range
Here are my questions.
1. I dont recall store ever performed borate test, and there is no reagent in TF100 either to test borate. Do I need to get some extra testkit/strip for that? I mean, I know it's one essential thing in BBB method.
2. How often should I check salinity of my water? Again, since TF100 doesn't have test for that, I originally plan to take water sample to do tests in the store monthly. Or i should get extra kit to test salinity more often during a month?
3. As you may see, CYA lvl is actually a little bit lower than recommended lvl(60~80 ppm), I believe. I plan to add some conditioner (liquid) soon. Since conditioner is not easy to dissolve in the water in short time period, and I dont want to run pump 24/7 for days. Is there solution for that? I remember someone from here suggests using sock as a "container", and pulling stabilizer into it, then hanging socks in the skimmer. Does that work for conditioner as well?
Again, thank you for your time and patience to ask my questions.
CYA: 50~60 ppm
salt: 2600 ppm
