I have the Pool Pilot DIG-220 SC-60 cell which produces 1.92 lbs of chlorine per 24 hours when set at 100% on cell power 3. I was wondering if anyone knows the relationship between power levels and purifier percentage and could answer the following:
At what rate does the production drop as you reduce the purifier percentage but keep the same power level?
Similarly, at what rate does the production drop as you reduce power levels but keep the same purifier percentage?
Is there some overlap between the power levels? For example is 50% power level 3 equivalent to 100% at power level 2?
Is there a chart or graph somewhere that shows the relationship between the two settings?
Also, regarding cell life, is it better to run the unit at a higher power level and lower purifier percentage or vice versa?
Thanks
Thanks
