Unfortunately after just adding a new VS pump to my system, my booster pump is now leaking water at the head and making some low level screeching noises (happened about 2-3 weeks after new primary pump went in). At this point I'm shopping for a new pump. The booster pump is 11 years old.
Is this the one option for the Polaris 280? Or anything else to consider?
http://www.amazon.com/Zodiac-PB4-60-Polaris-Booster-60-Hertz/dp/B000786GKS/ref=cm_cd_al_qh_dp_t
Also, what RPM should I set my primary VS pump when I run the cleaning cycle on the booster pump/Polaris? Or do I need to be running the primary VS pump at all?
