Results 1 to 8 of 8
Thread: Don't be afraid to apply BBQ sauce before smoking
    Mar 2008
    Central VA
    328
    From bbq.about.com
    Most of the things we call barbecue sauce contains sugars. Sugars burn at a temperature of about 265 degree F. If you are cooking above this temperature then the sugars in a sauce will burn and add a bad flavor to foods. Since smoking is typically done at much lower temperatures then you don't have to worry about adding barbecue sauces to meats during their smoking times. You might get some caramelization of the sugar but it won't burn and it won't cause you any real problems.
    Some of you purists / gurus in BBQ-ing probably wouldn't dream of using BBQ sauce while smoking, but from a beginner/mild intermediate BBQer's standpoint, I've smoked quite a few boneless breasts on my Big Green Egg, using soaked mesquite chips and brushing alot of store-bought BBQ sauce on beforehand. If I keep the smoker temp. at 200-250, those things are GREAT when they come off. Just some info. for any beginning smokers out there...
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    Nasty90's Avatar
    Apr 2008
    48
    Re: Don't be afraid to apply BBQ sauce before smoking
    I like to smoke too, I put a little malt vinegar in my basting sauce when using the smoker.
    35000 in ground vinyl liner with cartridge filter
    Birmingham,AL
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    We cut out sauce with cherry coke for chicken, makes a great basting sauce. But we don't apply it until the last 45 mins or so. We butter and rub the chickens first.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    I prefer to leave meats unbasted when on my smoker as I prefer to get the smoke to penetrate as deeply as possible.
    10,000 gallon in-ground pool, Jandy AquaPure 1400 SWG, Jandy Purelink Water Purification System, AquaLink RS Pool Digital Assistant, Jandy Stealth Series Pumps, Polaris 380, 3/4 hp booster pump, DE Filter, Lucayan Blue River Rok aggregate innerds
    Sauce?!? please please NO. rubs rubs rubs. please buy a pre-mixed rub. or if you know your spices and herbs, mix your own. the salt in the rub, penetrates the meat and helps keep the meat moist. i kno, salt? moist? but yes. dont sauce your meats til about 10 minutes befor they come off the grill. marinateing over night is good, and encouraged. but a good dry rub is worth its weight in tin (not gold because rubs are pretty cheap to make). BBQ sauce aint bad for noobs, but not before you grill, only about 10 mins before you stop grilling.
    Oh, and noobs, please let your meats rest for some minutes before you start butchering them. and please find out what "with the grain" means.
    Aug 2009
    SW Wisconsin
    518
    yep...die hard smoker here...NO SAUCE on smoked foods..you are just putting a "barrier" on your meat that blocks what the smoke is suppose to do and that is penetrate the meats. dry rubs only....you can mist the meat during smoking with some apple juice or applecider vinegar..but don't put any sauce on until it's time to eat.
    Also..a green egg is a grill, not a smoker to us purists.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    MyBad's Avatar
    Feb 2010
    AZ
    60
    We use a rub then a "mop" on most things, but I do like to sauce ribs once in a while.
    Looking to build a new POOL
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Quote Originally Posted by flyweed
    I don't know how you define yourself as a "purist" lol, but there are many of us professionals that use eggs for smoking, both in competition and catering. I've used a ceramic cooker once at the Jack as we couldn't get our units down there, it did a helluva job with some cherry and apple chunks (I avoid the chips).
    A green egg can be a smoker, and an awesome grill.
