So the pool was green when I opened it. I knew I had to shock it. CYA was at 0, FC was at 0. I put in 9lb of CYA to raise my CYA to inbetween 30-40. Let that run for two days. Then last night I put in enough liquid chlorine to raise it to 16 (the shock level for 40 CYA). I do my tests this morning (after being super sad that it was just as much of a cloudy mess as it was when I opened it (also note there is no debirs in the pool)). My readings
FC - 16
PH - 7.2
TA = 220 (I know its really high, but I assume this will get fixed at my current PH level once it starts getting aerated by swimmers)
CC = 0 (I'm not sure how this is zero the solution might have been SLIGHTLY pink from the kit, but it looked near as dangit to clear)
CYA = 45~
So those are my reading. Can anyone explain the extensive cloudiness? Should I put in clarifier?
FC - 16
PH - 7.2
CYA = 45~
