This is my 2nd pool slam not working nearly as well as last time. The pool is cloudy and is a blue green color sort of like sea foam green but more blue tinted and I can only see first step. Cya 35 chlorine 25ppm CC under .5. I can barely see a color change for cc. ta 130. PH? My gut tells me its low but have read testing not reliable. My pool has been at 25ppm chlorine and under .5 cc for 4 or 5 days and is showing no improvement in water clarity. My wife brushed entire pool 2x today. There were 2 white bleached Maple leaves in pump basket...we've vacuumed brushed backwashed filtered since may 12 I was balanced or so I thought when began slam water color was terrible for test.. I used bleach and trichlor until cya was 30 to 40 and now use bleach only. 8.25% unscented. I have no overnight chlorine loss and barely if any during the day maybe 1 to 3ppm loss daily if that for the past 4 days. 2 days ago i added 1/2 gallon of muriatic acid and the color shifted to more blue than green/white . also usex 6lbs of baking soda and a box of mule team weeks ago to get ta up to 80ish....it has climbed to 130 since. Probly trichlor 15k in ground sand filter 1hp superpump
