The numbers from this morning are:
FC 6
CC 0
PH 7.2
TA 150
CH 375
CYA 40
TEMP 86F
shows a CSI of 0.06.
But, it doesnt take much of a rise at all in the PH to raise CSI a lot, I guess due to the high TA and CH? And I'm guessing the TA has increased because I've drained some water, several times, to try to lower the CH but found out just 2 days ago the TA of the supply water (well water) tests to 240. PH was 7.4 and CH was 200 I think. I'm going to rerun that today sometime to verify it.
I'd like to lower the TA and/or CH some so the PH can be maintained more easily around 7.4 - 7.6. As it is I'm adding acid every day or two to keep the PH controlled.
So, continue to drain and refill to lower the calcium, then add acid and aerate for the TA??? Or, ??
