Gonna make the switch to Stenner/Liquid Chlorine setup.
Current Setup:
1. Pump - Challenger w/ Century A.O. Smith B2980T Dual Speed Pool and Spa Motor, 230V, Integrated Timer
2. Heater - Raypak 266BTU EI, 220V
3. Timer - Intermatic T102R - Pump/Heater wired to it, always on...pump runs 24hrs a day, integrated timer on motor controls hi/lo speed operation.
Even though not necessary, pump running 24hr is personal preference so actually timer function of intermatic not used; always on.
Thinking when I get Stenner, switch to P1353ME timer running in Mode 3 w/ Stenner connected to Circuit 3 (Cleaner) so Stenner will never be running unless Circuit 1 (pump/heater) is running/energized as well and I can control runtime of Stenner on Circuit 3 so I can used fixed-output Stenner ($70 cheaper).
So, line to timer/equipment pad is 220V, pump/heater at 220, figure a 45MPHP2 in 220VAC will do nicely with a #1 tube set to pump at night for whatever time I need set by circuit 3 timer of P1353ME timer. Being Circuit 3 of the timer should insure that chem pump never runs without main pump on if I ever decide I don't want main pump to run 24hrs.
If'n I woulda just planned this all out when I switched pump motors last year, I woulda gone with a pump motor without integrated timer and just controlled it all through P1353ME timer but alas, it is what it is.
Thoughts? Well, besides "What is this guy thinking?", anyway...
Current Setup:
