cya ............. 80
calcium hardness....425
ph..................7.5
fc....................5
cc....................0
total alkalinity ....100
these tests are from today..5/19...the levels have gone up and down over the past month...
...The draining half the pool is not good...I will check it out but I believe our water usage in this section of town is what our sewer user fee is based this particular time of the year.
Moving right along there!UPDATE...thanks guys..it looks like I am turning the tide...day 4 of the slam and I can see the bottom, main drain, of my pool...keeping the fc level as close to the 24 as possible[my beginning cya was 60]..color is returning to something acceptable..I keep this up until the pool is clear and the overnight chlorine loss is zero or very low?? is this correct?...assuming I reach this point do I then return to the regular testing of the water?...will I see a lower cya level when done slamming? my intention is to stop using 3inch pucks and just using liquid chlorine..is this a good idea?. can tablets be used occasionally when we are out of town?.. sorry for all the questions ...but I am enjoying not dealing with my lps...thank you..D
Another thanks to you all who commented on my problem pool...I stand victorious this round...my pool has never looked more blue er or more sparklier,,,,crystal clear!!
test results after slam...free chlorine still dropping
cya 40 was 60 at beginning of slam
fc 11.5
cc 0
ch 325
ta 110
ph waiting for fc to drop
I am all over the testing...first thing every morning and at the end of the day..chart says fc of 5...I will not drop below this number..Any comments as to what to watch for would be appreciated...I will be using liquid bleach not the pucks....if everything remains as it should is slamming necessary on a routine basis or just when the test results warrant it? crystal clear without the lps....D
