Alright, have a cloudy pool... Pool was "closed" by loading up the skimmers with bioguard smart tabs anywho, pulled cover off to find green as expected...
First test after 3 gal of 12.5% in 29,000 gal vinyl pool and followed by 4 gal the next day...
FC: 16
CC I think was 1
Ph: 7.7ish
Cya: 50-60
CH: 150
TA: 90
Added a gal to bump FC to about 20 per cya chart
Added what was left of lo n slo for ph
Tested later but didn't save them
Added 2 more gal to bump FC to around 24
Tested tonight after several days....
FC: 6.5
CC: 0
Ph 7.4ish
CH 200
I will say I'm surprised at how low CH is considering the pool has lived on granular chlorine, cal hypo and smart tabs. The pool is still very cloudy, can't quite see main drain in 8ft deep end. Water temp not checked yet but estimated around 50-55 degrees. Thoughts and opinions?
FC: 16
CC I think was 1
Ph: 7.7ish
Cya: 50-60
CH: 150
TA: 90
FC: 6.5
CC: 0
Ph 7.4ish
CH 200
