So this is the first time I ever owned a pool, it came with the house which was a foreclosure. I bought the house in March and when the block of ice melted I realized there was about 1 foot of leaves in the bottom. I got as many of the leaves out as I could scooping in the blind. The water was brown/green when I started the slam last week. (Monday 04/28)
water test in the beginning: FC 0
PH 7.3
CYA less than 20
I put 1.75 pounds of stabilizer in a sock and started using CYA of 20 as the shock level which was FC 10. I kept FC up between 10-15 for the last 8 days. It seemed to be going pretty good at first and the water cleared up to a cloudy aqua color within the first 2 days. It is now at the point where I can make out the vacuum on the bottom but not very good, water is still cloudy. I've cleaned the filter several times, maybe 5 times, an have been running it 24/7, I've scrubbed the sides and bottom and vacuumed the bottom most days. I was out of town for 3 days. My CC levels have always been 1.0 or less and even though the water isn't clear, I did the over night test the other day to see if I'm getting close, FC dropped by 2.
Today I checked CYA levels and its still below 20. I was much closer to losing the dot today than I was last week. I added another 1 pound of stabilizer hanging in a sock.
latest test results: FC 13
CC .5
CYA less than 20(trying to get it up to 30)
PH 7.4
So here's the question.... Is it normal to have to slam this long? The progress seems to have stalled. Is there something wrong with the filter or is this normal due to the amount of leaves that were in the pool?
Tavis
PH 7.3
CYA less than 20
CC .5
PH 7.4
Tavis
