Morning,
I'm hoping someone has a suggestion on how to fix a leak in my pac return line from the roof. IT looks like it's a bad PVC weld because it is leaking right at the 90 angle on the ground.
I don't think I have any room to cut in to replace the joint. Whomever put it in didn't leave much room between joints. They made a 90 to the ground, 2 45's right to give some separation from the solar panel feed line, about 4 inches of straight pipe , then a manual valve, another 4-5 inches of pipe and then a T for the bypass. I'll get photos tonite
I'm wondering if there's a PVC safe putty like JB Weld I could use to patch? Any suggestions?
