Results 1 to 7 of 7
Thread: Do ya think I have channeling?
    May 2008
    Fort Gratiot MI
    66
    Hey everyone,
    I have had my pool up now for about for about 1 1/2 months. I have never had the filter gain but maybe 1psi in pressure. I have regularly backwashed it as we have had alot of rain this spring and early summer. It has been about 2 weeks since my last backwash and still the thing hasnt even moved 1 psi. 1) Do you think I have channeling in the filter? I use Zeosand as the media and also have a skimmer sock that I check everyday and empty(We have had bad dogwood this year and it fills up almost daily) 2) could the gauge be bad? (its a brand new Doughhboy filter)
    Thanks in advance
    Brian
    24' round Vinyl liner Doughboy 48" deep 52" sidewall
    1hp Doughboy pump w/timer
    Doughboy Silica II filter with Zeosand
    Raypak 180,00 btu heater
    BBB method
    Sundance Optima '97 450 gal. spa w/Delzone ozonator
    Beats driving to the lake, and I'm only a block away from the lake!!
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Re: Do ya think I have channeling?
    I use a skimmer sock that catches all the small stuff. I rarely have to backwash. My pressure stays the same for weeks.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    My two cents
    I don't think you have a problem, a clean pool with a skimmer sock probally means that your zeo is not getting really dirty.
    Also i've read that zeo needs less backwashing , and if you have to empty your pool a lot because of rain i would suggest that you do it on waste.
    Keep an eye on your return pressure if that slows down and the pressure gauge stays the same, check the pressure gauge. If your water is clean and clear then i would say everthing is fine
    Happy swims
    Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    May 2008
    Fort Gratiot MI
    66
    Thanks for your help guys, yes it is clean and clear and I have no problems with it at all. The return has lots of flow. Ill keep and eye on that though.
    Thanks
    Brian
    BBB method
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    I don't think you have a channeling problem. Is there enything coming out of the return(like bugs/small things) Our pressure guage never goes up much. I know it's good because it's new this year and when I close the return valve, it goes up. Yesterday the pool was vacuumed and after the psi was 12(normal is 11.5), but I new it was dirty because the flow out of the return was very low. Backwashed and the flow went right back up.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Mar 2007
    Coastalish 'down easter'
    4,160
    Thanks Frank!!
    Luv& Luk
    -Ted
    Apr 2008
    Thailand
    152
    Posted: Wed Jul 09, 2008 5:14 am Reply with quote
    Thanks Frank!!
    No worries Waste
    stop hitting me with that hammer 8)
    happy swims
    Frank
