My light is a Pac Fab #70571, at least that is what the label on the light says should be used.
It is about 2 inches long and has a screw in base, a small one like a chandelier bulb.
I would like to get a LED bulb for it, but does anyone know if it will fit in this case? I think there is a case number on it also.
The bulb I took out looks more long and skinny than the LED lights I've seen.
EDIT: I found a picture of one it is #7 here:
http://www.poolproducts.com/aspx/shared ... 5=DEALTIME
I don't think I can get an LED light to fit here as it is a halogen bulb. How difficult is it to replace one of these?
Turns out it is a T-4 mini can lamp. Does anyone know if you can get an LED replacement?
END EDIT:
thanks,
David
END EDIT:
thanks,
David
