I bought a liquidator to go in my above ground pool but it isn't working right. I have my feed line hooked to the pump basket drain and it's not pulling a suction. My pump is running on high and it's outing out a ton of pressure into the pool but still not sucking from the liquidator. I called hasa and he told me it might be because it's an above ground pool and the pump is lower than the water level. Does anyone else have these installed on a above ground pool? If so how is yours set up?
