Re: New to the forum & a 1yr. old salt pool, need a little h
Ok thanks for that salt comment.
Bare with me here, I have another question cause I'm still trying to get my arms around maintaining the chlorine levels.
Yesterday I tested everything again and it all looked good but my FC was 4.5, CC was 0.5 and my CYA was 80. So I looked at the Chlorine/CYA chart and according to that my min. chlorine was to be 5.8 and my target FC was to be 9.1.
http://www.troublefreepool.com/chlorine-cya-chart-t2346.html
So I added some bleach according to pool calc and let my pump run on low all night and this morning my FC was 9.5 and CC was still 0.5.
Now that I look at this closer that was the wrong chart for my SWG pool isn't it?
I should of stayed with this chart:
http://www.troublefreepool.com/pool-school/chlorine_cya_chart_shock
But the reason I'm still somewhat confused about this is because on the recommended Levels page it says with a plaster pool, SWG, CYA of 70-80 my FC range should be 3-5
http://www.troublefreepool.com/pool-school/recommended_levels
Now I did see this also after the fact: (whoops)
Most saltwater chlorine generator (SWG) pools appear to prevent algae at a minimum FC level of 4.5% of the CYA level as compared with the roughly 7.5% of the CYA level shown in the "Min FC" column for manually dosed pools.
So it looks like when I used the pool calc last night that additional chlorine it recommended to get me up to the 9.1 FC level was for a none SWG pool and I was looking at the wrong chart. So if you have a SWG pool maintaining a FC of 3-5 or 4.5% of your CYA is what I'm supposed to be going by.
Is that right?
Now remember I just recently turned my SWG back on to 10% sand that was just 2 days ago after all the work I've done over the past week and half. So that really hasn't much effect on all this.
So it looks like I screwed up and overdosed my pool now
(dog gone it) and have to high of a FC level of 9.1. I have turned my SWG back off.
So in conclusion I guess my questions are:
1) So if my CYA is 80 that means I guess my Target FC should be 6 so what do I do now if anything with a FC of 9.1 ?
2) If my FC is way to high can I use some "Chlor Neutralizer" from Leslie's to bring it back down?
Can't wait to get all this figured out. JEEZE...
