I am by no means a plumbing expert, but I am guessing issues in plumbing under a pool are extremely rare. Drain plumbing is run under the pool on every pool built by any builder. In-floor cleaning systems all have plumbing run under the pool. Plumbing is run under house foundations in most houses built on a slab.
You also have to keep in mind that this particular PB uses heat bending on their pipes, so they won't have the issue of leaks at pipe joints. Pros/cons of heat bending pipes is a whole other topic to discuss ...
