Isaac-1 said:
p.s. I only mention this method as carrying cal-hypo is a lot easier than carrying bleach that is 90%+ water.
This is really the ONLY benefit I see using Cal-Hypo over liquid bleach. Cost in my opinion is not really a benefit as other members in the past have suggested. With a 15k gallon pool you will need a
25lb bucket to come close enough. This will raise your CH level up to 240 and add 129ppm of chlorine. This will run you about $100.
Now if you were to choose to use regular Bleach.......
You will start off by needing
15lbs of Calcium Hardness Increaser. This will run about $33.
Now to make up for the chlorine you gain using Cal-Hypo......
With Cal-Hypo IF you were to use the entire 25lbs bucket of Cal-Hypo (highly doubt it. Odds say your pool will hold chlorine well before you use the entire bucket) you will gain 129ppm of FC. To equal this much you will use 23 gallons of liquid bleach. At $3 a gallon (about the price I see at Wal-Mart) this will run you another $70. Add the Calcium to this and it's only costing you an extra $3 to use liquid. Cost again really isn't a benefit as other members stated in the past. I know this all sound confusing. In the end you will learn what your pool need, the terms and what each chemical does. If you have any questions we're here for you with any answers.
The main issue I can see is that I highly doubt you will need this much chlorine. My guess says that your pool should clear up VERY quickly. My gut (no real way of telling) says you will use about 1/2 the chlorine listed above. In the end I see you still needing to use liquid and adding calcium separate to reach your 250ppm goal.
Soooooooooo.......................
I would suggest keeping the two goals separate. I would start off by adding 3.5gallons of liquid bleach as soon as you can. Then test and add enough chlorine to maintain the FC level of 20ppm. The more you can keep your FC level at 20.....the quicker the water will clear. When you get the chance, purchase a 15lb bucket of Calcium increaser and add to the water.
and as always......please don't add the entire dose of any of the chemical's mentioned. Even though this is common sense.....I would hate to see a member get confused and mess something up greatly.
