- May 27, 2013
- 16
Hi all -
I've been using BBB since we moved into our new house about 3 months ago. When we moved in, I ordered the TF100 kit and started manually dosing the pool with 8.25% bleach. When we moved in, CYA was in the 120 range and I did a couple of partial drain/refills to pull it down to 50-60. Since then, we've been on autopilot with daily additions of bleach and muriatic as needed, nothing else has been added to the pool except we've been doing a little pumice stone scrubbing to remove some scaling that was there when we moved in - no chemicals just elbow grease.
This morning I took a full set of readings as follows:
FC - 7
CC - 0
PH - 7.5
TA - 80
CH - 180
CYA - filled to the top and could still see the dot
I repeated the CYA test and had the same result. Any ideas on how my CYA could be zero?
We've had normal use this summer, and there is a drain at the top of the pool's normal water level (maybe some drain out as we top off the pool daily). But I wouldn't have thought the CYA could have gone down 50-60 points?
I was thinking about taking a sample to Leslie's in case I'm getting a bad reading (my test kit is about 4 months old now)....
Thanks for any input or ideas you have...
FC - 7
CC - 0
PH - 7.5
TA - 80
CH - 180
