We replaced the cell (SC-48 with the RC-42) and put on a new cord. The tri-sensor cord remains and seems to be working ok. Since replacing the cell, we get 'warnings' ...clean/check cell and sometimes 'low amps'... The test was done when in boost mode. The salt levels are 3200 ppm,
the temperature is 82... The Volts are usually at 22 the Amps run from 4.7 to 5.4. All we did was replace the cell and cord. Did not go into any maintenance menus, nor did we bother the pump button.... Not sure where to go from here. The unit was replaced in 2009, we do have a huge surge protector on our incoming electric boxes (outside) and they are still showing green... but in SE FL...the power can be crazy.
Chlorine level is at 1 and residual at 1... Stabilizer is a bit low, but not 'gone'... Also need to add hardness to the water - these all based on test done at the pool store yesterday. I have what I need to add, but I was waiting to see what I needed to do re: the cell.... in case further tests might help.
Thanks so much....
Thanks so much....
