tests today
FC 9
CC0
PH 7.4
TA 100
CH 300
CYA 135
After slamming one week ago, the FC finally dropped below 10 to test the PH. I am still in the learning phase, and curious about the PH and TA effects on the water. I have a water fall on the spa and another waterfall on the pool. I see that aeration will raise the PH. The current reading for TA is 100 and to reduce to 80 to 90 I need to drop PH and aerate. Is my TA too high or should leave alone and retest in a few days? I will raise the FC back to 11 but wanted correct any PH or TA problems first. BTW, I am working to reduce CYA. Did partial drain before slam and reduced from 360. Will do again as water restrictions ease. Also does Polyquat 60 impact PH or TA. I am using while CYA is high
FC 9
CC0
PH 7.4
TA 100
CH 300
CYA 135
