Hi - please help!
I have a Goldline AquaRite SWG - has been running trouble-free since January 2006. We went on a trip and came back to a green pool - zero cholorine!!
The AquaRite has no lights on - meaning power LED light and generating lights are off - although it is showing the salt count to be 3200. I have kept it clean and serviced it at the proper intervals - so this is a surprise. It is hooked to a 2 speed pump and is on when the pump is on low - the pump is working.
I did check the fuse on the main panel - it is fine - I even changed it just in case - but that does not help.
Any help or suggestions are greatly appreciated!!
