- Jun 8, 2012
- 5
This is the 2nd time this has happened so far and I can't figure out what the problem is. We installed a new beaded liner in our pool. Everything was set to go, liner went into track no problem. Center seam was dead on, and the wall seam was against the wall all the way around. Most of the wrinkles out and shop vac turned on to set the sides. After about 18" of filling the I looked down and the wall seam on one end of the pool was at least 20" away from the wall under water. I turned the water and the shop vac off and within 1 hour the entire liner on that end came out of the track and continues coming out half way around the pool. I am only filling the pool with water on hot sunny days. It is an 18 x 33 Johnny W. pool. Oh yes one more thing, before we installed the new liner the first time we made sure the pool was level. Any suggestions would be greatly appreciated. Thank you
