Hi, just bought a house with a small pool. The old owner was using pucks in a hayward chlorine cl220. I stopped using them and removed them from the cl220. I've cleaned the filter too. The pool water was off from day one using test strips, so I bought a K-2006. I'm trying to use the BBB method, but having lots of trouble. 6000gal fiberglass pool. So, onto my results and hopefully you guys can help me start fixing it. Thanks in advance so much! I spent $140 on chemicals weeks ago when my pool started turning green, and what a waste.
Chlorine Test
FC is present, water is pink
Big one filled up to 25ml, 2 scoops of r0870
added 0871 and took 60 drops
12ppm FC was the reading. really high right?
there were no combined chlorines
PH
filled to 44ml, added 5 drops of R4
PH was under 7.0 color
base demand test required 32 drops
to get to a ph of 7.4
TA
25ml sample
after 2 drops of r7 and 5 drops of r8, color was a very light green.
after 7 drops turned a light pink
70ppm of TA
CA
Filled bottle to 7ml, then added R13 to get to 14ml. Mixed.
No cloudiness, no change in color.
Added to the small comparitor, the black dot never disappeared.
Chlorine Test
PH
TA
25ml sample
70ppm of TA
CA
