How expensive would it be to drain and fill? How high is you water table? I know we like to clean the water that's here but sometimes it make more economic sense to start over. Late to the party...
When you run a self-contained robot in a pool full of muck, the muck quickly fills the bag and the robot runs around on the floor for a couple more hours completely or partially clogged....wasting your time.(someone said that is not what the robot was designed for... meaning I shouldn't be running the vac?
ekins2011 said:I think we are getting there...
Chemistry:
FC- 26
CC-1
pH-7.2
Cya- 55
chem geek said:If you're just trying to get an approximate reading of a high FC level, then using a 5 ml sample isn't terrible for that. It roughly doubles the error from misreading the sample size. For high FC levels where this technique would be used, figure instead of a 10% error you might be off as much as 20%. If you're shocking and you are conservatively on the high side above recommended shock levels, then that may not be much of an issue.
Not enough concern to intentionally interrupt the slam. Somewhat low pH for a few days or so will cause no harm and SLAMmer can adjust, if necessary, once SLAM is complete and FC allowed to drift down.Does anyone see a concern on this point that his PH may be lower than 7.2?
ekins2011 said:I am so freaking excited! Look:
Two days ago:
I turned my filter off today because we were going to be out of town and I didn't want to blow it up. This was a sight to come home to :-D Progress...we are on day 7.
I wish I had known about using 5mL and 1 drop is 1ppm...seriously. I am out of the R-0871 and wont have any until Monday I have a Leslies and pool section at Walmart and a Hardware store...is there something I can buy there today to make sure I don't lose this progress. Something that will read up to 30ppm of chlorine?
Okay...cloudy water. Is there anything I can do or is it just running the filter and waiting?
I have not been testing pH just chlorine and cya (we tested a couple times because we used to have over 100 and have done a partial drain....well sort of...that fountain in the pictures leaks like crazy (cracks in plaster from being left dry in the sun :? ) and we have been bypassing it. So we allowed water to flow through that and slowly drain off and replace it...got the cya down to 55 and want to make sure it stays there).
jonjonathan said:You can get the 0871 reagent at leslies. That way you don't have to sit around waiting on the mailman. You can ask for it by the name of the FAS-DPD tritating reagent. It has a #2 on the label.
If it has a #2 on the label, it's DPD reagent #2. It's not a FAS-DPD reagent.jonjonathan said:You can get the 0871 reagent at leslies. That way you don't have to sit around waiting on the mailman. You can ask for it by the name of the FAS-DPD tritating reagent. It has a #2 on the label.
Now that the pool is almost sparkling clear, I recommend you do your homework and study in Pool School. If you follow our method of taking care of your pool, I believe you will never want to demo it again and never spend a grand to clear a pool.ekins2011 said:We have gotten to a light green cloudy color 5 times this summer but never clear. After our son was born last summer we neglected the pool because we thought it would be easy to get back to this:
I will shock up to 22 now and just try to be patient. We have not seen the bottom of the pool in over a year despite spending $1000s at the pool store (foolishly....seriously it hurts to think of how stupid we were.) Before this year we kept the free chlorine at 1 and never had a single problem...so I was thinking...hey owning a pool is super easy! I am getting to the point where I don't think it is worth the hassle anymore...someone talk me out of a demo. of my pool.
