TO SET TIMER
1. Move switch from OFF to PROGRAM then back to OFF - resulting single tone indicates Setting #1. Repeat until number of tones heard equals setting desired. ie 3 rapid tones is Setting #3
2. Move switch from OFF to RUN: to begin selected program setting.
SINGLE SPEED MOTOR SETTINGS
Setting 1 - Pump runs 24 hours Continuous (single tone)
Setting 2 - Pump runs 18 hours, off 6 hours (2 tones)
Setting 3 - Pump runs 12 hours, off 12 hours (3 tones)
Setting 4 - Pump runs 6 hours, off 18 hours (4 tones)
TWO SPEED MOTOR SETTINGS
Setting 1 - Pump runs 24 hours on Hi Speed (single tone)
Setting 2 - Pump runs 18 hours on Hi, 6 hours on Low (2 tones)
Setting 3 - Pump runs 12 hours on Hi, 12 hours on Low (3 tones )
Setting 4 - Pump runs 6 hours on Hi, 18 hours on Low (4 tones)
TO OVERRIDE TIMER SETTINGS
Move switch from RUN to OFF and back to RUN within 3 seconds. The pump will run for 1 hour and then return to the previous programmed setting. If a power failure occurs the timer automatically returns to the programmed setting.
