So my sand filter dial is leaking. looks like the previous owner had cracked the input port from the motor and applied some black joint compound all around it. its no longer doing the trick, so i am thinking i should just get a new valve kit. the original is a jacuzzi DVK-7 bolt-on. do i need to purchase that exact, or are there other vendors that have ones that fit the same? any other suggestions?
