- Jul 1, 2013
- 3
Hello all, new to the forum . I look to get some good advice as well as give whatever I can.
I own an Intex 16X48 AGP, with a saltwater system with a 1200 GPH pump.
Current setup: I have the krystal clear saltwater system, with the filter cartridge, going through an intex sand filter (model sf20110). The cartridge is removed, thus making the sand filter do the work. The water looks great.
I also have an extra saltwater clorinator, not hooked up. (it was originally hooked up with the sand filter).
Issue: I would like to hook up an automatic cleaner, but the 1200 GPH pump is not strong enough.
Solution: I am trying to get just the pump for this sand filter, then hook up the clorinator, new pump, existing sand filter.
Question: Can I get just a pump without buying an entire sand filter system?
Thank you for advice!
