UPDATED: New Pool Build in Granbury Texas
Update:
Electricians are done. Tile and coping this week with some stone work and the sheer descents hopefully. And a conundrum on how to upgrade my already installed Easytouch to intellitouch.
Howdy,
I've been lurking for quite a long time and I'm about to pull the trigger on a pool build. My lakehouse is not really all that fun when the lake is so low I can't use the boat or jump off the dock safely. So It's time to add a pool. I wanted first to submit the details as I have them to the collective wisdom/criticism of TFP. :blah: :blah: :blah:
General Specifications
Style - Rectangular
Size – 12.5'x~26'
Pool Square Footage – Approximately 336 Square Feet
Perimeter - 78'
Depth – 3 ½’ x 4' x 3 ½'
Acid Start-Up
Structural Specifications
Excavation - Bobcat Dig
Floor/Wall Steel Schedule - #3 10” OC, 5” x 10” OC in stress areas
Bond Beam Steel Schedule - #4 5” x 10” OC
Deck/Pool Steel Schedule - #3 Reinforcing Bar Deck Dowels 24” O.C.
Pool Structure - 8000 PSI Gunite
Walls - 8” Minimum (10-12" around skimmer), Floor - 8” Minimum (10-12" around drains), Bond Beam - 13" Minimum 36" tall
2 Bubblers in Tanning Ledge, 4 Pentair Laminar Color Jets along north side of pool.
Retaining wall breakout and sidewalk breakout
Screened soil for yard repair.
Sandstone Retaining Wall Build around pool shell and extended patio. New steps included.
Stable soil for retaining wall backfill.
Pool Equipment
Filter – 48 Sq. Ft Hayward DE Style Filter & Separation Tank
System Pump – 1 1/2 HP Hayward TriStar
Water Feature Pump – ??? TBD
Control - mechanical Timer
Cleaner – Polaris 280 (w/ Booster Pump Hayward 6060)
Erosion Type Chlorinator - Rainbow 320 In-line Automatic
Pool Lighting - 1 Pentair Intellibrite 5g Color LED Pool Lights, 3 Pentair GloBrite Lights
Main Drains - 2 VGB Compliant Anti-Entrapment
Skimmers - 2 Hayward SkimMaster
Returns - 4 Directional in Pool
Plumbing Specifications
Pipe - All 2” Schedule 40 (except as designated below)
3” Schedule 40 Manifold at Equipment Pad
1 1/2" thru-shell fittings
Dedicated return lines to equipment
Dedicated laminar and bubbler lines to equipment
Separate Skimmer Lines and Main Drain Lines to Equipment
Freeze Guard, Skimmer Protection, Never Lube Valves, Stub out for Fill Line.
Pool Coping and Tile
Tennessee Sandstone Coping
Waterline Tile – ??TBD??
Plaster – ??TBD?? Heavily leaning towards to Diamondbrite
Pool Decking and Drainage
Pool Decking - 390 Sq. Ft of 4” minimum poured concrete stamped and colored and sealed. Including Sidewalk to boat dock.
Concrete Reinforcement - #3 Reinforcing Bars tied on 18” Centers
Deck-O-Seal between Pool Coping and Decking
Gutter Drain – Yes, Tied into Deck Drains
Deck drains to yard.
Utilities Included
Pool Electrical Hook Ups - All Footage Included
Electrical Sub-panel with breakers with 2 mechanical timers (Later upgrade to Pentair IntelliTouch planned)
Layout on pad of equipment to facilitate adding Pentair Intellichem and chemical tanks as a later upgrade next summer.
Maintenance Equipment
Brush, Leaf Net, Telescopic Pole, Test Kit, Vacuum Head, Hose
Start-up Chemicals Included
Site Clean Ups
Gunite Clean Up
Final Clean Up
Warranties
Lifetime Gunnite Structural Warranty
2 year severe structural failure warranty
2 year plumbing warranty
1 year plaster from delamination warranty
3 year Polaris cleaner and booster pump unconditional warranty
Equipment Warranties by Manufacturers
Extra Items Included in Bid
GFCI Protected Electrical Outlet and Light at Equipment Pad
Volleyball and Umbrella Anchors
Update:
Howdy,
Style - Rectangular
Size – 12.5'x~26'
Perimeter - 78'
Acid Start-Up
Pool Equipment
Utilities Included
Site Clean Ups
Gunite Clean Up
Final Clean Up
Warranties
