zea3 said:
I have some questions. What size pump do you have? What type filter do you have? How forceful does the flow feel from the returns? When was the last time you cleaned the pump strainer pot? When was the last time you cleaned the filter?
ok....I think I have this correct. pump is Hayward 1.5 hp. filter is sand. I have never cleaned the sand. Build was done in late July 2011. SWG is pentair. Pump pressure is 12 psi at all times. I backwash often (maybe too often?). We have had to remove (backwash) water a bunch this year with so much rain. Because of rain I've stayed on top (I thought) of my water balence......bumping up chlorine output before storm etc.
I have two skimmers and 8 returns. Two of the eight returns are 1.5 inch threaded pvc. The other 6 are "eyes". The flow is forceful (seemingly same as it was right after build) out of all returns. There are two "eyes/jets" at the deep end swimout steps.....visible in pic posted of "clear water"......although pump was not running at time of photo.
edit.....filter pressure not pump pressure is 12 psi
This area where I think there is algae has the poorest circulation.....I know because that is where there is always dirt build up settling.
We clean out the basket at the pump on a regular basis (weekly?) when there is visible debris.
