Hi Everyone,
recently our pool water has given us trouble - was not an issue for the last 5 years that we have had the pool.
Issue: Even at 100% output, the SWG is not keeping up with the chlorine consumption. (We replaced the cell last year.)
Water became cloudy, FC to 1.0, so I shocked with bleach. Got it up to 12PPM FC - 0 CC and held it for 5 days- water cleared up again.
FC dropped from 10.0 to 1 in a week. Water became cloudy again. Yesterday I shocked it again to 8-10PPM, and it is clearing up again.
Water temp - around 75-78 deg these days.
CYA: 70PPM-ish
TA 70 PMM
CH - 210 ppm
PH I manage it to stay around 7.4 - adjusted with Muriatic Acid as needed
Salt: 2700ppm
At the return nearest the pool, we see offgassing of CO2 proportionally to the level of the SWG we set. It bubbles away happily. So I would deduce the SWG works well but I can't measure it directly.
Built 5 years ago
25K GAL inground, Quartz surface
Jandy Aquapure - replaced cell last year
Solar heat
Brand new 425SF cartriges in filter .
Location - NJ
I see no evidence of algae - so what could be the source of chlorine consumption? We had lots of rain (>6 inches) in the last weeks But I don'1 think that's an issue.
The use is light - mostly my kids and I and we are trained in pool hygiene )
So any ideas what might be wrong?
We're tempted to drain and refill (which we haven;t ever done in five years) but I'd like to avoid the trouble.
Thanks!
Patrick
CYA: 70PPM-ish
TA 70 PMM
CH - 210 ppm
Salt: 2700ppm
Built 5 years ago
Solar heat
Location - NJ
Thanks!
Patrick
