Just to clarify: When the pump is on and the jets are removed and the air inlet plug is removed, the air inlet does not gush water but it also does NOT suck in air.
I can see the water just sitting there down the pipe of the air inlet.
If I blow air into the air inlet with my wet dry vac then I get a ton of bubbles out of the jet outlets
As soon as I start adding jets then the water rises until the 5th jet is put in then the water gushes out.
There is nothing in the pipe in the second picture, I think the flash on the camera caused it to look black.
What do you mean without restriction? Isn't the purpose of the jet for the water to get squeezed out of a smaller and smaller orifice to create pressure and get a strong thinner stream of water?
