Ok, ready to open the pool up. Confident what I have learned on pool school last year will help me have much greater success this year.
I do have a couple questions. The water is green but I can see the bottom of the pool. I know I need to remove manually as much leaves, etc. as I can. I am wondering if I should vacuum to waste before I get me CYA and PH in the appropriate range before shocking or if I should remove what I can, get CYA and PH where it needs to be,run the filter 24/7 and shock? Last year I had used a flock treatment before shocking, which, was just before I joined this forum. Thanks!
