- May 12, 2009
- 107
This is our 4th season opening using the BBB method. Pool water was clear with no color, however this year the water level was about 12 inches lower than it should have been. We usually drain the water to below the skimmer and for some reason it is a foot lower than normal. I have checked all around the liner just above the water line and above and couldn't find a hole/tear. Not sure if back when we closed we had about 4 inches of rain if that might have pushed some of the water or displaced some when it weighted down the winter cover. Anyways...we refilled the pool last night and are hooking up the pump and parts this evening. Is there anything different I should do since the water level started to low this season?
I plan to let it circulate all tonight and then our 1st water sample in the morning, or should I test tonight after we get things running. I figure CYA will be low if even there since we basically had to replace 2/3 of the water. There is some dark sediment in the bottom from leaves, etc that I need to vacuum out. Just need to get my bearings and get this show on the road.
Help! and thanks in advance.
