I opened my pool on Saturday and started the conversion process Saturday evening. By Monday evening my water was looking great. I tested my water this morning and had the following results:
FC - 19 ppm
CC - 4.5 ppm
Ph - 7.5
TA - 130
CH - 220
CYA - 0
Although the water is beautiful looking, there is still a lot of dirt and dead slime in the pool. I do not have an automatic cleaner of any sort, so it will take a bit to get the rest of the dirt out. Because of work I can't attend to the pool as much as I did this weekend. What is the next step? I don't want to change out the sand in my filter until I have all the stuff on the bottom of the pool out. Do I continue to keep the water at high chlorine? Should I start adding CYA, or should that wait until I change out the filter sand? Thanks for your help
FC - 19 ppm
CC - 4.5 ppm
Ph - 7.5
TA - 130
CH - 220
CYA - 0
